Get process CPU utilization using API
Is there any api to get the highlighted details in below snapshot for a process group?
I tried the metrics v2 api’s in https://community.dynatrace.com/t5/REST-API/API-Get-detailed-CPU-consumption/m-p/102104 , however they are for Metrics only. How can I get the highlighted details:
- Name
- Type
- CPU usage at mark
Hi @vikas_sood,
Try Metrics API - GET metric data points with builtin:tech.generic.cpu.groupTotalTime
HTH
Yos
builtin:tech.generic.cpu.groupTotalTime isn’t returning any data. I am seeing data only with cpu.usage and cpu.totalTIme.
Ok, so I am able to pull builtin:tech.generic.cpu.groupTotalTime  from dynatrace for a process group. However, I also need to pull the cpu consumption by all processes in process group along with the process name. Is there any API for that?
