Get the build logs for React Native
Why do we need the build logs?
When running npx instrumentDynatrace in the terminal it will generate some information about the instrumentation and it will show errors if there are any. Those information are useful for the information.
How to get the build logs?
You can find the build logs in node_modules/@dynatrace/react-native-plugin/logs or in the terminal after running the instrument command. See screenshot for reference:
NOTE: You can copy/paste the logs into a .txt file for easier investigation.
@yngwie_lucero thanks for sharing this
