Grail and JSON formatted logs
If upgrading to Grail, does anyone know if it will allow us to treat log messages formatted in JSON and query by key/value pair?
Hi GregOReily
Yes its posible you can use the Json parse
or you can do a processing rule to math only the keys that you need before storage and next query them in grail without parsing
Based on my comprehension, it is feasible.
Regards
To clarify, these are features only available in grail, not available in Log Management today?
DQL is only available in Grail.
Best regards
Thanks, I gathered this would be the case.
