Hardware components
Any ways to extract hardware information, cpu model etc. into dynatrace?
Hi @clc
Basic information can be found on the host tab in the section: Properties and tags.
Other information is not automatically captured. We can add manually information using: Define tags and metadata for hosts — Dynatrace Docs
Hi @clc
You can send additional metadata for hosts and then use the API to get every entity and their details (properties)
Metadata for Hosts: Define tags and metadata for hosts — Dynatrace Docs
API Get Entity: Monitored entities API - GET an entity — Dynatrace Docs
This is a response body example of what information the entity gets: Monitored entities API - GET an entity — Dynatrace Docs
BR,
