Has anyone integrated Dynatrace with Ketch?
We are looking to use the “Opt-in Mode” and would like to integrate that with Ketch. https://www.ketch.com
I looked, but I am not seeing any out of the box integrations between the two products.
Has anyone done this? How did you go about it?
Thanks!
Hello Larry,
The Ketch seems to be a new feature. Could you create an RFE here so development can review it and consider adding support for Ketch integration in the future?
