Rohitk
1
Hi Team,
We have noticed some performance issues and suspect that heap memory usage may be a contributing factor.
Specifically, Can we get the details of the following things
- The amount of memory used by each object
- The amount of memory used by each method and located memory
This information will help us optimize our code and reduce memory usage.
Hi @Rohitk,
You can use the memory profiling. Requirements: form java 11. Very useful tool.
Memory profiling | Dynatrace Docs
At previous java versions you can only trigger a memory dump which can be analized in another tool (eg. VisualJVM).
Memory dump analysis | Dynatrace Docs
I hope it helps.
Best regards,
Mizső
