Hi Dynatrace,
Can you please provide some guidance how to use entitySelector to retrieve host data by host name?
I tried different options but none successful. Here is one example:
…/api/v2/entities?entitySelector=type(‘host’),tag(‘Hostname:xxxxxx’)
Note: I can retrieve the host info by entityId using entities/{entityId} but that means I need to retrieve and/or maintain a separate map of hostnames to entityIds.
Also, do you have more info about how to interpret API error messages?
Ex: what should I understand from this output?
“error”: {
“code”: 400,
“message”: “Constraints violated.”,
“constraintViolations”: [
“path”: “entitySelector”,
“message”: “The requested type is not exportable”,
“parameterLocation”: “QUERY”,
“location”: null
Thank you
