Hidden values in SQL statements
Hi all,
I’m trying to extract significant KPIs from the SQL queries detected by Dynatrace SaaS.
Within the SQL statements some values are hidden and are represented by the “?” character.
How can I display them in clear text?
Thank you,
AD
Antonio, I believe those are Bind variables you are seeing. Bind variable capturing is coming soon and is available as a beta feature for certain technologies. I suggest you reach out to your sales team and explore if it can be enabled for your tenant.
I believe this is coming but only for Managed clusters for the time being - see Michael Kopp’s posts here: https://community.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/183009/rfe-capture-sql-bind-values.html
James is correct (as usual). Only for Managed.
Thanks to all for your reply. I’m asking to sales team if it can be enabled.
