High CPU usage detected for python datasource running configuration 3fb4e1a6-fc85-3813-809d-b058de039a37. Restarting
We are having high CPU usage on one of our extensions resulting in failed overnight ingestion.  What designates higg CPU usage on an extension, and what % is high ?
check the code and see the recursive functions you’ve it may because of infinity recursion or processing big data records without limitation statements or chunking it.
Here is the information about what the limits are for extensions: About Extensions — Dynatrace Docs
