Hi everyone,
I’m working with Dynatrace Managed on prem and a custom JMX extension to collect HikariCP metrics.
I can successfully collect metrics from both:
- com.zaxxer.hikari:type=PoolConfig
There is however an important difference between the two:
PoolConfig exposes a PoolName attribute → I can define a dimension (e.g. pool.name) and split metrics per pool
Pool does not expose the pool name as an attribute → the pool name only appears in the ObjectName display, not as a key property
Because of this, when multiple Hikari pools run in the same JVM, Dynatrace:
- collects Pool metrics correctly
- but aggregates them at JVM level
- making it impossible to split runtime metrics (ActiveConnections, IdleConnections, etc.) per pool
Example:
- Pool A: IdleConnections = 2
- Pool B: IdleConnections = 5
- Dynatrace reports: IdleConnections = 7 for the same process
This makes per‑pool monitoring and alerting unreliable.
Constraints:
- I cannot modify the application code
- I cannot change how HikariCP exposes its JMX MBeans
- Only the Dynatrace side (extension/configuration) can be adjusted
Question:
Is this a known limitation with HikariCP JMX in Dynatrace Managed?
Is there any supported Dynatrace‑side workaround to avoid Pool metric aggregation when multiple pools exist in the same JVM?
Thanks in advance for any feedback or guidance.
My extension code :
version: 1.0.1
minDynatraceVersion: 1.303.0
author:
metrics:
- key: hikari.connections.active
metadata:
displayName: Hikari Active Connections
unit: Count
- key: hikari.connections.idle
metadata:
displayName: Hikari Idle Connections
unit: Count
- key: hikari.connections.total
metadata:
displayName: Hikari Total Connections
unit: Count
- key: hikari.threads.awaiting
metadata:
displayName: Hikari Threads Awaiting Connection
unit: Count
- key: hikari.connections.acquired
metadata:
displayName: Hikari Connections Acquired
unit: Count
- key: hikari.connections.created
metadata:
displayName: Hikari Connections Created
unit: Count
- key: hikari.connections.timeout
metadata:
displayName: Hikari Connections Timeout
unit: Count
- key: hikari.config.connection.timeout
metadata:
displayName: Hikari Connection Timeout
unit: MilliSecond
- key: hikari.config.idle.timeout
metadata:
displayName: Hikari Idle Timeout
unit: MilliSecond
- key: hikari.config.max.lifetime
metadata:
displayName: Hikari Max Lifetime
unit: MilliSecond
- key: hikari.config.validation.timeout
metadata:
displayName: Hikari Validation Timeout
unit: MilliSecond
- key: hikari.config.minimum.idle
metadata:
displayName: Hikari Minimum Idle
unit: Count
- key: hikari.config.maximum.pool.size
metadata:
displayName: Hikari Maximum Pool Size
unit: Count
- key: hikari.config.leak.detection.threshold
metadata:
displayName: Hikari Leak Detection Threshold
unit: MilliSecond
- key: hikari.config.keepalive.time
metadata:
displayName: Hikari Keepalive Time
unit: MilliSecond
- key: hikari.config.initialization.fail.timeout
metadata:
displayName: Hikari Initialization Fail Timeout
unit: MilliSecond
jmx:
groups:
- group: hikari
subgroups:
# POOL (pool.name depuis ObjectName)
- subgroup: pool
query: "com.zaxxer.hikari:type=Pool (*)"
dimensions:
- key: pool.name
value: property:name
metrics:
type: gauge
value:
attribute: ActiveConnections
type: gauge
value:
attribute: IdleConnections
type: gauge
value:
attribute: TotalConnections
type: gauge
value:
attribute: ThreadsAwaitingConnection
type: count
value:
attribute: ConnectionsAcquired
type: count
value:
attribute: ConnectionsCreated
type: count
value:
attribute: ConnectionsTimeout
# POOL CONFIG (pool.name via attribute)
- subgroup: poolconfig
query: "com.zaxxer.hikari:type=PoolConfig (*)"
dimensions:
- key: pool.name
value:
attribute: PoolName
metrics:
type: gauge
value:
attribute: ConnectionTimeout
type: gauge
value:
attribute: IdleTimeout
type: gauge
value:
attribute: MaxLifetime
type: gauge
value:
attribute: ValidationTimeout
type: gauge
value:
attribute: MinimumIdle
type: gauge
value:
attribute: MaximumPoolSize
type: gauge
value:
attribute: LeakDetectionThreshold
type: gauge
value:
attribute: KeepaliveTime
type: gauge
value:
attribute: InitializationFailTimeout
