We are using an OTLP Java SDK to push metrics to a managed instance of Dynatrace. While we can successfully push UpDownCounters and Gauges we are unable to push Histograms. We do not see any errors in pushing but the Histograms are not visible
Histograms are enabled in the Dynatrace instance.
We have attached the following document:
- Metrics.txt (This is the JSON view of the metrics that are being published).
metrics.txt (6.17 KB)
