Host Availability percentage for more than 500 hosts
How can I extract host availability for more than 500 host in excel from Dynatrace Saas/managed.
Is there any API that can help to extract this data?
Hi @JyotiSingh ,
The easiest way is getting the data from data Explorer using this metric: builtin:host.availability.state
Then, enabling flag “Advance mode” and removing :limit(x)
Finally, exporting the data to csv.
Hope it helps.
Elena
Hi @JyotiSingh
In top of what Elena is saying, you can also use Dynatrace API to read the same metric:
@JyotiSingh , @erh_inetum and @Malaik are correct. The API will give you the RAW Json in which you can then ingest it into excel and massage the data as you see fit to provide a proper format as needed.
Thanks this was the easiest solution & it worked for me.
