I have tags being generated based on hostgroup name. For my on-prem server based on a specific hostgroup name convention new tags will be auto generated. I am facing difficulty setting hostgroup name for Fargate services is it not possible to set this parameter?
Thanks in advance
Fargate is serverless, if you not use EC2 cluster to run your workloads. I think it is not possible to define. Maybe someone else correct me if I am wrong.
For serverless, for example PODs in not clussicfullstack monitoring I use this:
...env: - name: DT_TAGS value: web-502 |
For example for me it is add tag ‘web-502’
Also you can try to tag what you want as you wont with combination of rules
Romanenkov Alex
