with oneagent options you can set the HOST ID generation source to IP Adresses. We have done this for preemptible K8s nodes on GCP to avoid the creation of hundreds of hosts in Dynatrace (an ever growing list since preemptible nodes can go and disappear at any time).
After applying the parameter in the Dynatrace Operator I’d have expected the list of hosts becoming shorter but it seems that this option considers all IP addresses of the host and therefore doesn’t really have an impact.
Specifically I do have a host naming rule that takes the last octed of the host IP and renames the host:
However I still get two hosts created over the course of time, where I’d have expected only one:
I believe this is due to the fact that the hosts also get different public IP addresses?
(.33 vs. .198)
host1:
host2:
Would be great if someone could confirm this how it is done in detail? Are all addresses used or one? Which one?
The documentation of the HOST ID parameter says ip-addresses (pl.), though the description says ip-address (sing.). Also the Naming rule only understands one Host:ipAddress.
Thanks!
