Host or monitoring unavailable
we have Oneagent monitoring on my servers in Full stack mode. recently we have been observing  Host or monitoring unavailable   alerts though i can see my host is available and running. i went through the docs where i found the alerts can occur if there is Network connection loss.
If there is Network connection loss to the monitored host , how can we identify this, and what fix/solution can be applied to avoid the Network connection loss
Hello Athira,
which operating system and version of the OneAgent are you using here?
Have you tried a deinstallation and installation of the OneAgent already?
Christian
PS: I cannot open your link.
Hi @Athira,
You should see some gaps on any collected metrics at the affected host. In case of high CPU consumption / CPU saturation maybe OA did not have any CPU time and could not collect and transfer the monitoring data…
I hope it helps.
Best regards,
Mizső
