@Andreas G. and Team, Please help us with this.
How Appmon used to detect the individual domain/host as a separate application, Dynatrace oneAgent is not detecting Hosts/Domains under My web application in Applications.
PFA screenshot of Purepath got detected but the application, and we are expecting to see the Host based on header value
Questions:
1. If the content type is Non HTML, is there a way we can customize in Dynatrace to see the Requests related non-HTML contents (e.g. Content-Type: application/json) under Applications/My web Application?
2. Is there a way we can split the traffic based on Host header values? Please see the screenshot attached from Purepaths, need your help in detecting the application based on Request Header value. In this case we are hoping to see the host api.test.com as a separate application under My web application
When we reached to the Dynatrace support team, we were told “We can see that there is never an HTML document being loaded for either of these apps. Since there is no HTML document being loaded, the Ruxit Agent can never be properly injected for any of those apps, which means, we will not be able to capture data for these apps, and put them in the corresponding application”
