Hello community,
I’m in the process of transferring dashboards from Splunk Cloud to Dynatrace (I’m getting the same data into a dedicated bucket).
I try to count the number of events per hour and per entity, in order to get an idea of the hourly load over one or more days (for example knowing if a type of event often occurs at the same times). So I made a simple graph that can show me this:
But I have a problem: I would like this graph to start at the 00:00 page and end at 23:00. time page and displays the number of events per entity each hour. But he must also know how to adapt if it takes several days. I’ll give you examples of what I did on Splunk, maybe it’s clearer (example on 24 hours of data and example on 7 days of data):
24 hours
7 days :
My order is as follows:
fetch events
| filter source == "OnCall" and alertType == "CRITICAL"
| filterOut in(routingKey, array("dynatrace_event", "mpb-dynatrace_event"))
| fieldsAdd routingKey = if(routingKey == "dynatrace_2", "Dynatrace", else:if(routingKey == "servicepilot_prod", "ServicePilot", else:if(routingKey == "control-m", "Control-M", else:if(routingKey == "dynatrace_mfe", "Dynatrace MFE", else:if(routingKey == "control-m_mfe", "Control-M MFE", else:if(routingKey == "dynatrace_amm", "Dynatrace AMM", else:if(routingKey == "control-m_z-os", "Control-M Z/OS", else:if(routingKey == "mpb-control-m", "Control-M MPB", else:if(routingKey == "mpb-dynatrace_problem", "Dynatrace MPB", else:if(routingKey == "dynatrace_f02", "Dynatrace F02", else:routingKey))))))))))
| dedup incidentNumber
| makeTimeseries count(), by: {routingKey}, interval:1h
I tried another approach that allows me to see what I’m looking for in table form but I can’t convert it to a graph:
Do you have any idea how to do this (if it’s possible)?
Sincerely,
Red
