How can I achieve sending Dynatrace alerts to HPSM?
There is no out-of-the-box integration between HPSM and Dynatrace but you can choose between two alternative possibilities:
- Use xMatters to integration with Dynatrace and HPSM, see here: https://www.xmatters.com/integration/hp-service-ma…
- Use the Dynatrace ‘Custom integration’ to push Dynatrace alerts into a HPSM REST API.
