I use Dynatrace OneAgent monitoring
You can fetch all relevant Real User Monitoring metrics from the Dynatrace REST API. See here:
Hi, I need fetch the metrics of Dashboard ?
(I used this option in Appmon)
There is no combined dashboard fetch but you can get the individual metrics through the timeseries API.
Does that mean I can’t get an Apdex rating?
My goal is to read “Apdex rating” through the API
Can you write me an example of such a request?
https://<YOUR_ENVIRONMENT_ID>.live.dynatrace.com/api/v1/timeseries?relativeTime=hour&aggregationType=count×eriesId=com.dynatrace.builtin:app.apdex&queryMode=total&Api-Token=<YOUR_TOKEN>
Very Thanks.
I monitor page load time (with Key), Is it possible to retrieve through the API what page load time
again thanks
