How can i monitor RHEL cluster?
we are looking for DT solution to monitor RHEL native cluster (Pacemaker);  does DT provide an extension for this type of monitoring?
Hi @joanne_quan,
I think there is not an OOTB extension in DT for pacemaker.  Maybe you can use the event ingestion API:
Events API v2 - POST an event | Dynatrace Docs or if this pacemaker has logs, you can collect them and search patterns in them for alerting.
I hope it helps.
Best regards,
Mizső
Thanks Mizső for your response; at least we have the starting point on how to pull metrics /logs from RHEL cluster.  It the moment, we do not have the scope what to monitor on this yet.
