How to add alerting for a disk path utilization in a linux host if it is above 80%?
Hi @Arunkumarbnp ,
By disk path if you mean standard paths like /var or so Dynatrace will by default monitor these. You can check and set the thresholds under Settings → Anomaly Detection → Disk edge.
If you mean you want to monitor specific file, filesystem monitoring extension would work better here.
You can read about this here:
Filesystem monitoring monitoring & observability | Dynatrace Hub
@Maheedhar_T
