How can we check how much storage space we consume for PurePaths?
dynatrace has information for code level insights, that is PurePath, and keeps it for 10 days.
In addition to that condition, actually, dynatrace saas has also limitation of storage(30GB) for PurePath, doesn’t it?
(Maybe, in other hand, users can change that limitation for dynatrace managed.)
We’d like to know how to check it especially on dynatrace webGUI.
Kohei
Hello @Kohei S.
Open any node of the cluster in the console and there you will find a transaction storage info along with other.
Babar
Hi @Babar Q.,
thanks for your comment!
Is this the same for SaaS environment?
Hello @Kohei S.
I have a managed setup but it should be the same even for the SaaS.
Babar
No, der Cluster Management Console (CMC) from which the screenshot is taken is only available on managed.
There is no way for a customer to see the storage consumption for a SaaS environment.
