ASE
July 14, 2024, 2:28pm
1
As we continue to grant more users access to Dynatrace, we want to ensure we can track any and all Settings changes.
Is there a way to view all Settings changes made and by whom?
It’s not always easy to view Revision History for every single setting, without clicking into every single setting.
In some cases, there is no Revision History .
Thank you.
The changes are available through the Audit logs:
ASE
July 14, 2024, 5:23pm
3
Thank you for your reply, @AntonioSousa .
We will make sure to enable this.
ASE
July 15, 2024, 4:08pm
4
We’ve just enabled Log Audit Events and can now see what we needed to see.
Is there any other way to view the audit logs outside of the Dynatrace REST API? Something a little more non-technical user friendly and easy to read.
For example, are the audit logs visible via the Logs & Events app like other system events are?
Base on documentation , only via API.
You can raise a product idea .
Best regards
Starting relatively recently (~ June 2024), settings audit logs are also written to the dt.system.events bucket so can also be queried via the Logs & Events app in advanced mode - a starting point might be the query
fetch dt.system.events
| filter event.provider == "SETTINGS"
| sort timestamp desc
