I am trying to enable Dynatrace OneAgent Monitoring for IBM WebSphere Application Server, the installations was complete using root as per requirement, the user used to run IBM WebSphere Application Server
The .profile file of the user that is used to start IBM WebSphere Application Server was amended and added with the following:
export DT_HOME=/opt/dynatrace/oneagent
export LDR_PRELOAD64=$DT_HOME/agent/lib64/liboneagentproc.so
export LDR_PRELOAD=$DT_HOME/agent/lib/liboneagentproc.so
Is there anything I am missing.
ISSUE: We even after restarting the IBM WebSphere Application Server process, we are still getting a prompt to restart the process.
Screenshot of WebSphere even after restarting the process, automated injection not working.
