How do I get past this?
Hello Bill,
Hope you are doing well.
From my understanding Dynatrace is unable to download source code for .NET core libraries. At this point there is no workaround.
Since .Net core is open sourced by Microsoft I would recommend searching through their documentation if you know which classes you want to see.
Are you trying to use this feature to troubleshoot your application? It might be beneficial to pull the code that was developed by your team that implements .net core.
-Dallas
Is there an update? I’m having the same problem. My code is .NET and it calls Source code for DbCommand.
Hi @JuanRergisG
Unfortunately, the situation hasn’t changed significantly since the original answer given by @Dallas . Dynatrace cannot download source code for .NET Core framework libraries. This is a product limitation rather than a configuration issue, so there’s no workaround on the Dynatrace side.
Sujit
