How do I tag entities using Management Zones?
The entity selector documentation says I can use mzName(“name”) or mzId(“123”) to apply automatic tags, but in practice, this doesn’t work.
Can anyone help me?
Example in the attachment.
In fact, the doc says that you can use the mzName;mzID in the entity selector API call.
It seems that it can not be used when applying Auto tags based on entity selector rule.
