I have followed this link below to setup monitoring notifications from azure to dynatrace but I am not seeing any azure alerts in Dynatrace. Is there a way to test the integration to ensure that webhook is good and Dynatrace is ready to receive alerts?
We have always used https://webhook.site/ to test webhook data being sent or received as well as review the data being passed.
Thank you, Chad. Much appreciated.
You are very welcome! @Salman N. if you feel my answer solved your question, please select the check mark “answer” and award points as you see fit.
Thank you!
