Hi All,
I was trying to update multiple alerting profiles in an environment.
For now, i have done it with an offline automation that involves Settings API.
(Settings API - PUT an object | Dynatrace Docs)
But this option updates the Settings schema one by one, as we need to update the Object Id in the above API for each of the profile.
I was looking for a more one stretch solution. Even tried using monaco deploy, but seems monaco can create but not update existing settings.
Let me know if there is any other method i can go with.
