We have a question about the Dynatrace Managed cluster uninstallation.
We have referred following document, but we could not find the way in case of one node cluster. https://www.dynatrace.com/support/help/installati… https://www.dynatrace.com/support/help/installati… The document says that run “/bin/sh managed-installer.sh --uninstall”. But we guess that managed-installer.sh does not exist in our machine. Could you tell us how to remove one-node Managed cluster?
Best Regards,
Noah Kobayashi
Hi Noah,
I believe this is the shell script that you also use to create a new node. You can get it by:
wget -O managed-installer.sh https://xxxx.dynatrace-managed.com/nodeinstaller
best regards
Franz
There is a script for uninstalling the node completely:
/opt/dynatrace-managed/uninstall-dynatrace.sh
hmaran
July 15, 2024, 8:31am
4
When trying that, I get:
bash-5.1# /opt/dynatrace-managed/installer/dynatrace-managed-installer/uninstall-dynatrace.sh
COMPONENT_HOME is not set in /opt/dynatrace-managed/installer/dynatrace-managed-installer/uninstall-dynatrace.sh
I found nothing on Dynatrace managed docs about it. Any ideas on how to proceed?
Go to your folder install dynatrace managed and find with this path
