How do we view and confirm our current Data Retention Period values?
I need a little clarification on this.
  1. Are any of these retention values configurable?
    1. The way this chart reads, only Log Management and Analytics is configurable. Is this correct?
  2. Are these retention values visible anywhere in Dynatrace?
    1. We want to view them and confirm these values in our environment.
      1. We specifically want to confirm our Grail Metrics and Classic Metrics values.
Thank you.
Hi @ASE ,
If you go to the Cluster Management Console (CMC) → Environment → click on the environment name (example: prod)
from there you can increase/decrease the limit.
I hope this helps!
Esam Eid
Thank you for your reply, @Esam_Eid.
Is the CMC visible in both Dynatrace SaaS and Dynatrace Managed customers?
I can’t find the CMC in our environment.
no CMC in SaaS
Hi, quick question,
Is the current retention an automatic setting, or can we configure it as well? For me, it automatically changed from 15 days to 5 days.
