ntanaka
February 26, 2019, 12:18pm
1
I understand the Linux memory metric are read from /proc/meminfo.
https://community.dynatrace.com/spaces/482/dynatrac…
Now, I wonder what metric of /proc/meminfo dynatrace use to calculate Linux memory usage.
I guess the answer is following;
memory usage (%) = (MemTotal - (MemFree + Buffers + Cached)) / (MemTotal) * 100
Is it correct?
If it is different between Redhat Linux version 6 and 7, I would like to know the difference.
Best Regards,
Natsumi Tanaka
ntanaka
February 26, 2019, 12:34pm
2
I am sorry to overlook this document
https://www.dynatrace.com/support/help/how-to-use-dynatrace/hosts/monitoring/measures-for-host-health/
It says;
memory_used = total_memory_size - (free_memory + active_memory + inactive_memory + reclaimamble_memory)
So, I guess these metrics can be replaced with /proc/meminfo metrics like following;
memory usage (%) = (MemTotal - (MemFree + Active+ Inactive + SReclaimable)) / (MemTotal) * 100
Do you think it is correct?
Best Regards,
Natsumi Tanaka
@Natsumi T. Dynatrace calculates memory usage as:
we have seen this to be correct across all platforms
Thank you for your answer!
