How is the location of data center detected in Dynatrace?
In some customer environment, I can see which data center the host belongs to while some other I can’t. What makes the difference and it works actually?
Hello @Wai Keat C. ,
For physical servers , City of the server is mentioned as DC location .
For virtualized infrastructure , DC is detected from vmware , AWS , Azure .
PLease refer below link from official documentation :
https://www.dynatrace.com/support/help/insight-dis…
As a simple test , you can install oneagent in your local machine and point it o DYnatrace SAAS instance and it will show you your machines’s oneagent residing in a DC(name of your city).
Regards
Himanshu Mor
Hey Wai,
Also, if you set up IP ranges in Settings → Web & mobile monitoring → Map IP addresses to locations and your hosts fall into those IP ranges, it will also determine that location as a Datacenter. This is a manual way of defining your own Datacenter configuration in Dynatrace.
NJ
Hi Himashnu
Our physical and virtual servers are located in Australia. But in the properties of host - it is showing as UnitedStates.
Any idea from where it is picking Unitedstates as Geo Location.
settings → Web & mobile monitoring → Map IP addresses to locations  - No location is mapped here
