How many URLs can one HTTP Monitor handle?
Can someone let me know how many URLs can a HTTP monitor hold/monitor?
I’ve ~400 for an application so thinking whether if it can be done in one.
MH
I would create one HTTP monitor per URL.
I think no limits in relation how many HTTP monitors can be created per tenant.
Best regards
Thanks but I was looking for an answer “how many URLs in one HTTP test”?
MH
What Anton mentioned is best practice, if there is no data being passed from 1 request to the next then we recommend that a separate HTTP Monitor is set up per request. That way if one of the requests fails you can still get data from the later ones.
The max number of requests per monitor is 200
The limit for monitors (HTTP Monitors + Browser Monitors + 3rd party) is 5000 per tenant
Thank you @AntonPineiro, @HannahM
