How much use speed bandwidth for install file dynatrace
Now, download file dynatrace very slow. customer want to know how much use speed bandwidth for download.
Server images are approximately 1.1GB in size, OneAgent bundles are 1.3GB, ActiveGate bundle ~0.5GB, Synthetic is 0.15 GB. The rest is very small.
As your cluster downloads those from mission control, you might want to check the speed, but the installation does not require any specific bandwidth.
Hi Julius L.
Do you have any references or documents that mention this?
thank you
You can see the sizes after they have been downloaded or in another Dynatrace Managed installation.
