I am trying to understand how oneagent gets installed and how it works? We only supply the below 2 parameters in startup.sh script and restart the tomcat and out of the blue everything starts working but what i want to understand is how it does it internally like how this magic happens?
What does this library (liboneagentproc.so) do as we supply it into LD_PRELOAD_64 environment variable. We are not even mentioning it into JVM parameters then how it is injecting itself?
LD_PRELOAD_64=$DT_HOME/agent/lib64/liboneagentproc.so
export LD_PRELOAD_64
