Summary
This article explains how to add experimental properties to a Dynatrace Browser monitor script. Experimental properties are typically used during Dynatrace Support troubleshooting to enable additional diagnostics, or temporary behavior changes in Synthetic Monitoring Browser clickpaths.
With a few exceptions, many of these settings are not documented publicly and should only be applied when explicitly requested by Dynatrace Support.
When to use experimental properties
You may be asked to configure experimental properties in a Browser monitor script when:
- Dynatrace Support is investigating Synthetic Monitoring failures or inconsistencies
- Additional diagnostic data or logging is required
- A change in behavior of the Synthetic player is needed for a small use-case
Experimental properties are support‑guided only. Adding undocumented properties without guidance may lead to unexpected monitor behavior. The only exception to this are those documented in the Troubleshooting forum.
How to add experimental properties to a Dynatrace Browser monitor
Follow these steps to safely add experimental properties to a Browser monitor script.
In Latest Dynatrace Synthetic app
1. Open the Browser monitor
- In Dynatrace, navigate to Synthetic.
- Select the relevant Browser monitor.
2. Edit the monitor script
- Click Edit monitor settings.
- Open the Advanced Setup tab.
3. Add the experimental property
Expand the Experimental properties section
Select Add property
Enter the Name and Value
- Replace
propertyNameandvaluewith the exact details provided by Support. - Do not modify or add additional experimental properties unless instructed.
4. Save and deploy
- Click Save.
- Execute the Browser monitor to ensure the changes take effect.
In Classic Synthetic
- In Dynatrace, navigate to Synthetic, or the Synthetic Classic app.
- Open the script editor for the Browser clickpath.
Locate the
configurationsection of the monitor’s JSON configuration. -
Add the experimental property using the format provided by Dynatrace Support:
"experimentalProperties": { "propertyName": "value" }​For example:
- Replace
4. Save and deploy
- Click Save.
Validation
After applying the experimental property:
Verify that the Browser monitor executes successfully
If errors occur or the issue persists, share the updated script with Dynatrace Support for further analysis
For related Browser clickpath scripting guidance, see:
How to interact with trusted events in a Browser Clickpath
How to remove/ disable an experimental property
When an experimental property is no longer required, remove the property that was added during troubleshooting:
- Latest Dynatrace Synthetic app: Open Advanced Setup → Experimental properties and delete the property entry.
- Classic Synthetic: Remove the corresponding code snippet from the monitor’s
experimentalPropertiessection, or the entireexperimentalPropertiesblock if no other experimental properties are configured.
After removing the property, save the monitor and execute it again to validate that it runs successfully.
FAQ
Are experimental properties officially documented by Dynatrace?
No. Dynatrace does not publish a public list of experimental properties. With the exception of small number documented in the Troubleshooting forum, they are provided case‑by‑case by Dynatrace Support.
Can I use experimental properties in production monitors?
For any documented in the Troubleshooting forum, yes, these properties are production-suitable. For others, only if explicitly instructed by Dynatrace Support.
What’s Next
If this does not resolve the issue, please open a support ticket and provide
- a link to the affected monitor
- mention this article and any other troubleshooting steps taken
Related reading
Classic Script mode for Browser monitor configuration
