I would like to calculate availability for Database :
It must be shown in the ratio when there is no data or Offline Database :
How can I do it with DQL?
Julien
If I understand correctly the logic of this metric:
using 0 makes it difficult to use metric value directly, but fortunately we have rollup:total (formerly known as rollup:count) which will have value of contributions or nothing when metric was not reported.
If we define availability as a % of moments when database was online vs. moments when it was in any state, this query should do the job:
timeseries state = sum(`sql-server.databases.state`, rollup: total), by: { database.state, database }, filter: database.state=="ONLINE"
| lookup [
timeseries state_all = sum(`sql-server.databases.state`, rollup: total), by: { database.state, database }
], sourceField:database, lookupField:database, fields:{state_all}
| fields interval, timeframe, database, availability=100*state[]/state_all[]
I also assumed that for intervals with no state, we should have no data on the chart (or null in timeseries)
Kris
Thanks!
How can I also include “No Data” as “Failed” in the score?
Yes. default: parameter is helpful here.
timeseries state = sum(`sql-server.databases.state`, rollup: total, default:0), by: { database.state, database }, filter: database.state=="ONLINE"
| lookup [
timeseries state_all = sum(`sql-server.databases.state`, rollup: total, default:1), by: { database.state, database }
Thanks ! :clap:![]()
