Hello Team I need to calculate duration between start time and end time of timestamp
Can you please elaborate more on your use case? Do you have a record with a start and end timestamp and want to calculate the duration? Or do you want to calculate the duration between two timestamps of two different records?
Best,
Sini
I am looking for find difference between two timestamp:
I have two events, first events is orderComplete’s timestamp follow by agencyComplete’s timestamp event. Here the DQL:
fetch logs, from:-4h
| filter dt.security_context==“prod-srv0-isi”
| filter endsWith(log.source,“isi.log”)
| filter contains(content, “agencyComplete”)
| parse content, “DATA json:ac”
| filter isNotNull(ac[feed][csId])
| fields agencyComplete_Timestamp=timestamp, csNumber=ac[feed][csId]
| join [
fetch logs
| filter contains(content, “/orderComplete: input”)
| parse content, “DATA json:OC”
| filter isNotNull(OC[order][systems][0][csNumber])
| fields orderCompleteTS=timestamp,csNumber=OC[order][systems][0][csNumber]
], on: csNumber
The result is something like this:
agencyComplete_Timestamp,csNumber,right.csNumber,right.orderCompleteTS
“2024-01-03 20:15:32.634”,“D065079302”,“D065079302”,“2024-01-03 20:12:28.302”
“2024-01-03 19:53:34.111”,“D065079299”,“D065079299”,“2024-01-03 19:49:59.684”
I would difference between these two timestamp.
PVThach
Hi @paulthach,
I have a solution I think.
I’m testing it on my side, and I’ll share it with you today if it works.
I’m not very sure about my query, but you can try this:
| filter dt.security_context=="prod-srv0-isi"
| filter endsWith(log.source,"isi.log")
| filter contains(content, "agencyComplete")
| parse content, "DATA json:ac"
| fields agencyComplete_Timestamp=timestamp, ac_csNumber=ac[feed][csId]
| lookup [ fetch logs
| filter contains(content, "/orderComplete: input")
| parse content, "DATA json:OC"
| fields orderCompleteTS=timestamp,oc_csNumber=OC[order][systems][0][csNumber]
],sourceField: ac_csNumber, lookupField:oc_csNumber, fields:{orderCompleteTS}
| fieldsAdd delay= orderCompleteTS - agencyComplete_Timestamp
| fields ac_csNumber, delay
Thanks you gbaudart,
I like your use lookup, lookupField, and sourceField. I was able to come up with similar solution as follows:
fetch logs, from:-24h<br>| filter dt.security_context=="prod-srv0-isi"<br>| filter endsWith(log.source,"isi.log")<br>| filter contains(content, "agencyComplete")<br>| parse content, "DATA json:ac"<br>| filter isNotNull(ac[feed][csId])<br>| fields agencyCompleteTS=timestamp, csNumber=ac[feed][csId]<br>| join [<br>fetch logs<br>| filter dt.security_context=="prod-srv0-isi"<br>| filter endsWith(log.source,"isi.log")<br>| filter contains(content, "/orderComplete: input")<br>| parse content, "DATA json:OC"<br>| filter isNotNull(OC[order][systems][0][csNumber])<br>| fields orderCompleteTS=timestamp,csNumber=OC[order][systems][0][csNumber]<br>], on: csNumber<br>| fields agencyCompleteTS, orderCompleteTS=right.orderCompleteTS, duration=(unixSecondsFromTimestamp(agencyCompleteTS)-unixSecondsFromTimestamp(right.orderCompleteTS)) ,csNumber
