How to capture the return value of a method?
Is it possible to capture the return value of a Java method in Dynatrace?
Best Regards,
Fousseyni B.
Yes you can.
Settings → Server Side Service Monitoring → Request Attributes.
Create a new Request Attribute and in the Data Source section, specify “Java Method Parameters”.
Once you’ve defined the class.method, you will be provided a pulldown to choose the ‘Return Value’ value of the specified method.
Here’s the doc page which describes this feature. https://www.dynatrace.com/support/help/monitor/tra…
