How to capture XMLEelment data using Request attributes in Dynatrace
Hi Team,
We need help to capture XMLElement data using Request attributes. XMLElement is present as one of the .net method parameters, Please see the example below.
Is there a way to capture the below value.
<TransStart.startRequest code="Endorse" effectiveDate="2014-04-30" scheduleDate="" autoCommit="0" />
Ameya
Hi @Ameya D.,
First of all, not sure you will be able to capture this argument - depending on its length. That being said - once you have it, you can try the post processing rules to capture the only part that is interesting you.
