Hi Dynatrace team,
1. suppose, On XYZz host’s CPU has increased to 99% , we got the alert for same and how to find the threshold values for this XYZ host.?
2. How to fetch the report or data of application CI list in Dynatrace tool.?
Hi Dynatrace team,
Hello @Kundesaibaba,
1. Dynatrace detects the host abnormality based on AI. So there is no define thresholds you can see. But this can be tweaked base on custom settings at anomaly detection → host.
Also you can set static thresholds for host abnormality by creating events . see below screenprint.
Threshold in red dotted line during alert generation
2. What do you mean by application CI. Can you specify.
Is it host properties or host details?
Checkout Environment v1 API
Cheers!
RN
Question, @RazTN7 . You mention the default threshold for infra anomaly detection is based on AI… did this changed recently? As far I remember, there were a page in old docs that refer to the static thresholds (which I could not find anymore) for the infra anomaly detection. In UI we see them as Automatic, but behind the scene it was using the static threshold as we see when change to “based on custom settings”.
So does this works as baseline now?
Thanks.
Hello @dannemca
Yes. Please ref - Adjust the sensitivity of anomaly detection for infrastructure — Dynatrace Docs
But the matter of fact I relay on Metric Event when it comes to static alert detection. I dont prefer to change the automatic detection to “Base on custom settings” with static value.
RN
Yes, that’s exactly how it works.
@RazTN7 is right ![]()
