Hi everyone,
I’m working on configuring Dynatrace to send alerts specifically from two mobile applications directly to Slack. I have a few questions:
- Should I first create a Management Zone for these two mobile apps?
- What kind of rules should I define to make sure the Management Zone includes only those apps?
- Once I have the zone, how do I set up the alert so that only events from those applications are sent to a specific Slack channel?
I’d really appreciate any guidance or examples you can share.
Thanks in advance!
