How to configure using Dynatrace Recorder Browse Click Path for application which launches a JRE Oracle Forms in a new window or Citrix Based Apps or in Application a new window open up
When we go to the home page of the application, there are several App that are hosted in Citrix. When we click on those apps they will get launched in a new Window that is not Browse based one. But we need to record those Transactions to analyze the performance.
Dynatrace Synthetic uses a Chrome extension, so is unable to record or playback applications that are not Browser-based.
If you are already testing using another product you can feed the data back into Dynatrace using the third party synthetic api
If this is still an issue, there are options to solve this problem and feed the data back into Dynatrace.
Feel free to contact me directly at koen.derkinderen@inetum-realdolmen.world
Hi Koen, would you mind later sharing the solution with the Community as well? It can help others in the future facing the same kind of trouble :wink:
