How to create a Dashboard for Process Group Instances of a Specific Service
Do I have an easy way to create a dashboard with how many process group instances a specific service has?
It can be in Classic Data Explorer or new dashboards using Grail.
Best regards
@AntonPineiro Can you please try below ?
fetch dt.entity.service
| fieldsAdd  process_group_instance=runs_on[dt.entity.process_group_instance]
| expand process_group_instance
| summarize process_group_instance_count = count(), by:{id,entity.name}
Yes, thank you so much!
Best regards
