we are having this capability in AppMon but not seeing this in new Dynatrace. do we have same feature or equivalent in Dynatrace?
This works rather different in Dynatrace. Read about Request Attributes here: https://www.dynatrace.com/support/help/server-side…
Business Transaction functionality is not available in Dynatrace. You can use Key Requests in Dynatrace which will work in similar way as of your BT and it’ll baseline those key requests URL automatically. You can see more details in the below link,
Regards
Muthu
This is a misunderstanding, most of all functionality is available. Please see my first comment.
The most interesting parts are probably
* Request Naming which is most akin to BT and BT splitting: Set up request naming in Service Detection v1 — Dynatrace Docs
* Multi dimensional analysis: Upgrade your custom charts now — Dynatrace Docs
* Custom Business Errors: Configure service failure detection in Service Detection v1 — Dynatrace Docs
Thanks, Michael. I meant the same but didn’t put in right way ![]()
can we generate reports based on these?
