How to create Custom Metric and Report in Dynatrace Managed?
What are the steps to create Custom Metric and Report in Dynatrace Managed?
You can use the following ways:
R.
According to report I think it will be best to get metrics via timeseries api as Radek said and push them to some other tool like Konami, there you will be able to create reports. Or if it will be enaugh for you you can create dashboard with custom charts.
