How to create dashboards for different components?
Sometimes you have a dashboard that contains the same parts (metrics, tiles…) for a different component.
So, the same thing, I edit the json format, copy past the identic part and change all the new labels, names, … for the new component.
That help me and save my time.
Thank you for sharing this tip @Malaik!
Our “Knowledge sharing” challenge is no longer active, but I moved it to the “Dynatrace tips” subforum, where you can post all your hints and advice for using Dynatrace.
And for posting in this forum, you’ll also get some bonus points, that will help you climb our ranking ladder :wink:
Hello @MaciejNeumann
Good news.
