how to create dql to check database failed connection
Hi
have created dashboard tile using builtin:service.dbconnections.failure, this shows  failed connection count.
I want to imeplement the same using DQL , how I can do that. I did not find matching key in grail metric list.
My final aim is to check this count and send alert/email to team.
Heramb Sawant
This metric, along with other service metrics, has not yet been converted (for example, calculated service metrics).
Have you tried retrieving this metric from a DB Extension 2.0? This approach might provide additional insights.
Hi, I have the same need but cannot find this metric neither in the extension.
Has anyone found any alternate solution for built-in metric like: builtin:service.dbconnections.failure to be queried in Grail?
