How to delete PaaS token?
Everything is in the question, how to delete paas token ? I created a paas token in the " deploy dynatrace " menu and I don’t know how to get rid of it.
ps: I’am using dynatrace managed
Hello Gilles,
To delete a PaaS token please follow these steps:
1. Go to the environment that the PaaS token is being used
2. Settings → Integration → Platform as a Service → Identify the token that you wish to delete → Select the “X” to delete it. (shown below)
Matt
Or alternatively use the token management API to delete or rotate them.
Best greetings,
Wolfgang
