How to detect plummet / spike in metric like disk free % before they are a problem?
What is the recommended approach to detect a sudden surge in a metric like disk free?
Some context:
  • My Prod environment has 60k Disks so automation is required
  • I am using a Workflow with Davis Forecast Task to predict future disk space exhaustion.  However the Workflow runs once a day and will not detect sudden surges in disk usage spikes that occur in between runs of the Forecast.
  • These surges in disk usage can cause disk free % to plummet in 1-2 hours but aren’t yet low enough to register a Problem in DT.  e.g. 80% free to 20% free in an hour (see graph below)
Assuming our Workflow Forecast will catch slow disk growth over time, how can we detect sudden dips in disk free %?  Was considering creating a calculated metric for rate of change but thought that was too heavyweight.  Also was not sure if Anomaly Detection was appropriate for this use case.  Any thoughts?
Thanks!
I think anomaly detection through either a metric event or Davis Anomaly Detection would solve your issue here. You can set an auto-baselined threshold to be “outside” the bounds, which would alert whether the data points dip or surge. You can tweak the sensitivity of the auto-adaptive threshold as well to suit your needs. We use this across all of our servers, with different thresholds for OS drive versus other drives.
